メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Time Capsule モデル A1302は、2009年3月に発売されたAppleの第2世代ワイヤレスルーター兼ネットワークストレージデバイスです。これらの修理・分解ガイドに記載されている情報のほとんどは、初代モデル A1254にも適用できます。
Time Machine internal drive replacement using SSD instead of HDD?
Hello Everybody.
My A1302 Model internal Hard Drive is soon going to RIP (keep getting constant errors that the Disk Image can't be created / Is damaged ) so a drive replacement is imminent.
My question is, would it be wise to replace the internal drive with an SSD ? Or should I stick with a standard HDD ?
The old drive is a 1TB and i'm going to use a 1TB drive as a replacement.
Thanks is advance for your help.
Cheers
E_
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
How it ended? Have you noticed increasing speed? Or some different experience?
さんによる 共有
Cuál es el máximo de almacenamiento SSD que podría admitir esta unidad A1302? Gracias
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
It depends! It you are using the drive for backups then stick with a HDD as it’s cheaper when getting into the larger sizes. If you are using the drive to augment your data storage with direct access then you might go with a SSD. Even still the Time Capsules I/O speed is not very fast so you may want to get a better external drive.
このアンサーは役に立ちましたか?
スコア 4
6 件のコメント:
Hy Dan & thanks for your answer.
Seen that there's no price difference nowadays in France between an 1TB HDD and SSD I think I'll go for the SSD.
Less power consumption, less noise and as stated in a few articles here
How do I Upgrade the new AirPort A1470 to SSD?
, write speeds over ethernet are a lot faster.
This here looks like a good replacement Crucial CT1000BX500SSD1 but any suggestions are welcome.
Cheers
E_
A quick thought … if i put an SSD inside, is there a specific place a have to stick the temperature sensor back on ?
さんによる 共有
I was thinking 4 to 8 TB for the drive as often people need deeper storage. But a one TB drive also works!
It’s not the Ethernet speed that holds you back the SATA controller logic Apple used won’t deliver what the current generation of SSD’s can offer.
Place the sensor near the drives connector as that’s where the micro-controller is,
さんによる 共有
@danj Thanks for your insight on the subject.
Cheers
E_
さんによる 共有
What is the maximum SSD storage that this drive supports?
Tanks
さんによる 共有
@dani47292 - I wouldn't go to large as the WiFi and SATA logic is not that powerful in this series. A 4TB is what I would go with. Others have used 8TB drives.
さんによる 共有
1以上のコメントを表示
コメントを追加
回答を追加する
eric さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 45
今までの合計 5,371
