Hdmi port not working
When I plug the hdmi port into my gtx 1070 it don’t work but when I plus in the display port it works fine how do I fix this
You'll maybe have to open up the card to do this. Get a needle or similar and gently nudge each pin from the port connecting to the board. If any move they will need re soldered. Solder cracking is pretty common, especially in devices that get hot.
このアンサーは役に立ちましたか?
Ok I will try it
You prolly need to go in and update your drive for the hdmi port!!!
このアンサーは役に立ちましたか?
How do I update hdmi drivers
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 942
