メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Kenmore Direct Drive is a washing machine by Kenmore.
Help me identify Mystery Part
I found this mysterious part laying under the control panel on my Kenmore coin operated washer model number 110.27272600. The about an inch and half long. Please help identify what it is.
画像
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
When you say "....under the control panel..." do you mean that you removed the console panel and found it there or was it lying under the coin box?
Are you sure that it belongs in this washer?
Here's the parts list for the washer and it doesn't appear to be in there as a separate part, unless it has broken off another part that is.
Is the washer still working OK?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Yes, just found it laying there, under the control panel, not coin box.
The part was found when I went in to remove a clog at the drain pump, washer is working now. Just can't figure out if this fell out of one of the controls, timer, maybe lid lock.
さんによる
Thank you for posting such a clear copy of the parts diagram!
さんによる
@Rizwan Hussain
Looking at the parts list, the timer is in the coin box. (see p.5 part #12)
I looked online at images of the lid lock, lock strike and a few other parts by searching for their part numbers but nothing looked like what you posted
さんによる
コメントを追加
回答を追加する
Rizwan Hussain さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 20
今までの合計 301
