I loose power when accelerating and sometimes when in traffic
Intermittent stalling immediately after starting or punching gas. Sometimes also in traffic. I have tried changing the CVT, testing sensors, What might be the issue?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like a fuel injector issue. Could also be a vacuum leak.
このアンサーは役に立ちましたか?
I have to check this...But how would I check a vacuum leak ?
That is difficult unless it is a big leak and you can hear it. Disconnecting or pinching off vacuum lines might give a clue, but that involves much understanding of what you are affecting. My bet is on the injectors.
Hi mate. Did you fix your problem?
What if your throttle was clogged?
このアンサーは役に立ちましたか?
I've fixed a clogged catalytic converter that did something like this. I drilled a 3/8" hole in it.
might be fuel filter also that need to be cleaned or replaced..
過去 24時間: 4
過去 7 日: 7
過去 30 日: 24
今までの合計 653
