メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nokia Lumia 730は、2014年9月に発売されたWindows Phoneです。4.7インチのディスプレイ(画素密度は約316 ppi)と、6.7MPのリアカメラを搭載しています。
How to fix reboot?
Suddenly reboot continuously , network not working 😞 what's the solution for this ? When enter the camera app the mobile is restart , set high volume the mobile also restart .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi!
Usually in cases like this you may have to flash new software on the your phone as there may be software problems causing the phone to restart. You may want to try to restore your phone using the Windows Device Recovery Tool.
Please be aware that this will almost certainly erase all the data on your phone. So backup any important information BEFORE you connect your phone to the program.
  • If your phone is still restarting after flash your phone software then I would next recommend opening the phone to check for any signs of physical damage or liquid damage. If you feel comfortable opening your phone, follow this YouTube guide to disassemble your phone: https://youtu.be/yLCwTk4DlYs
Please note: You will need a set of Torx screwdrivers and opening tools to remove screws and parts, both of which are readily available on the iFixit store and on Amazon.
  • Check for any signs of corrosion or obvious signs of liquid having come into contact with the motherboard (usually will present as green or white powder like substances, though may be different colors)
If neither of those fixes do not help you then your phone may have a fault with the motherboard. At that point I'd recommend contacting a professional to have the specific program diagnosed.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
You can download the Windows Device Recovery Tool from Microsoft using the link below:
https://support.microsoft.com/en-us/wind...
さんによる 共有
コメントを追加
回答を追加する
Madheswaran M さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 354
