メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年10月に発売されたGoogleのスマートフォン、Pixel 6の修理および分解情報。モデル番号GB7N6およびG9S9B16で識別されます。
Pixel 6 touch screen less precise after replacement
I have had my Pixel 6 screen replaced after a big crack.
After finally fixing the fingerprint sensor issue, I still find myself with a major problem:
The touch screen is less "precise" when typing fast. Namely, when I am writing fast and touch the screen in two points almost simultaneously, it interprets it as a "swipe", and therefore misses the first of the two touches.
This had never happened before the change. Is this a known issue, or could it be a problem with the new screen itself?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
This is likely a defective screen. See if you can get a refund or replacement. If it was a cheap screen, it may just be very low quality.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks, that was also what I thought. It was however not a cheap one, and was (according to the seller) an original piece. Will ask for a refund
さんによる
コメントを追加
I have this same issue and also when I call someone the screen flickers
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi. I don't have an answer, but I also got my screen (only the touch part) replaced by a third party (Pixel 6 wasn't launched in India) and have the exact same issue. How did you fix it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Davide Di Nello さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 15
今までの合計 1,162
