メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sanyo VPC S1275は、パナソニックの子会社である三洋電機が製造した1200万画素のコンパクトデジタルカメラです。
The "OK" button does not work
The "OK" button of my camera does not work anymore. Is there a way to fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Does it feel like it's somewhat stuck when you press it? If it does, give it a good cleaning by following the advice from this answer by Reed Crosby; you may also want to follow this replacement guide and open the camera (steps 1-5) to check if there's anything under the button preventing it from working correctly.
The button may as well be physically broken: to confirm this, first ensure the control panel buttons are in good condition, then complete said replacement guide and reassemble the device, apart from the function set strip. Now turn the camera on and test the OK btn, you can navigate through the menus by pressing directly on the control panel using a pointed tool like a pencil. If everything works, you just need to buy a spare part and replace it (or salvage for parts from a broken device); otherwise there's a more serious damage and the device needs to be inspected thoroughly
Hope this helps, feel free to ask if you have any more questions
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you so much for the help! And yes, it does feel a little stuck when I press it. I will try to open the camera to check what is causing the problem. It´sa really good camera and it would be a shame not to use it.
I´ll try to let you know if I can fix it!
さんによる 共有
@Francesca Glad it helped, of course feel free to post any updates and let us know how the repair is going
さんによる 共有
コメントを追加
回答を追加する
Francesca さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 31
今までの合計 1,192
