メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How I can fix my drone
My sjrc f11 4k pro drone has fallen into sea, Somehow i found it but thr Battery was very warm, also the joint of Battery and drone covered with red rust. Please advice me how i can fix to fly Again my drone. Thanks in advance....
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@hplabon79 for now do not charge or plug your drone into power. That can potentially make a bad situation worse. this is going to be tough since I suspect the motors having gotten submerged and those most likely cannot be opened. Anyhow, what I would start with is reassembling the complete drone. Most of it will be plastic etc., so it may snap together or there may be some screws. Use something like this video to work on that. Once opened and disassembled you want to clean all the parts with some high grade isopropyl alcohol. Use something like this guide iPhoneの水濡れ・水没ダメージからの復旧方法 to clean your circuit boards etc. It was written for an iPhone but the cleaning steps can be used for your circuit boards as well.
Your motors can be submerged if they cannot be opened and you may want to use a small amount of canned air to blow those out after. As for your cameras etc, hard to say if they will survive the water damage. You can clean those with isopropyl too but you may get (residual water) stains on the lens. You must replace the Battery. At this point its a bit of a gamble but in reality you got nothing to lose. Good luck and let us know how it works out.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Hasan plabon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 668
