The Display Frame is Bent!
Hey everyone,
my MacBook dropped on the top left corner and the corner was bent. I turned the area with the Apple logo back. But the Frame around the Display is still bent and without removing it I can´t turn it back. Only the upper part of the frame is bent and doesn´s "fit" to the rest of the display. I have no idea how to fix this problem. I think if I remove it it´ll be even more bent. Is the Frame easy to repair if I remove it or will it brake if I try? Another idea I had is to use a very strong glue to stick it. Any problems with that? If I could I would buy a broken Display Assembly but buying a new one is new solution to me! Is there any shop that sells the frame oder a display assembly(without LCD!) on his own?
Already now,
Thanks for help!
この質問は役に立ちましたか?
