メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Do I need to replace entire trackpad or just the brackets?
Macbook Air Late 2010: Trackpad. The mechanics of the trackpad only work correctly when pressed on the bottom right corner (it goes down and back up as expected). The bottom left corner is permanently depressed and cannot be pressed or clicked.
I am not sure if I need an entire new trackpad or if the issue can be corrected by replacing a part, such as the brackets and screws that iFixit sells. The trackpad works fine otherwise, especially using the "tap to click" function, which does not require depressing on the trackpad. However, I would still like to fix this issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
I'm suspecting your battery is pressing on it. Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
さんによる
I second @danj's comment; a swollen battery could be pressing on the trackpad from the bottom and keeping it from working. Definitely a good idea to take out the 10 Pentalobe screws on the bottom of the case and check the condition of the battery; you're looking for any that are pillowy and no longer flat.
さんによる
Thank you both. I will take a look and follow up. Just ordered the tools I need from ifixit.
さんによる
The battery was swollen. Once I replaced it, the trackpad functioned properly. Thanks again for your help. I appreciate it.
さんによる
@Jose, Awesome! Congratulations on a successful repair and not having to replace your trackpad. :)
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Here's the needed battery MacBook Air 11" (Late 2010) Battery and here's the guide MacBook Air 11インチ Late 2010 バッテリーの交換
If the trackpad its self is failing then here's the needed part MacBook Air 11" (Late 2010) Trackpad and the guide to put it in MacBook Air 11" Late 2010トラックパッドの交換
Replace the trackpad for a MacBook Air 11" A1370 Late 2010 laptop model.の画像
製品
$29.99
Replace the 4790 mAh battery compatible with MacBook Air 11" (2010). 35 Watt Hours (Wh), 7.3 Volts (V).の画像
製品
$49.99
MacBook Air 11" Late 2010 バッテリーの画像
ガイド
難易度:
中レベル
15 minutes
MacBook Air 11" Late 2010 トラックパッドの画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Just opened it up. Battery is swollen. Looks like I'll be ordering a battery.
さんによる
@Jose - Don't forget to score the answer and accept it - You should be good once you put in the new battery. Enjoy!
さんによる
コメントを追加
回答を追加する
Jose さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 18
今までの合計 263
