メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Texas Instruments社によるビジネス専門家や学生向けの一般的な金融電卓、TI BA II Plusの修理ガイド。
Why is my zero key not working?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi
There are a couple reasons for why your 0 key isn’t working ,here they are!
1) the most common reason:under the key the membrane has gotten dislodged or dirty so you should clean the board and membrane with some isopropyl alcohol to potentially restore functionality
2) it could be caused by a loose connection or a broken trace:to check for a loose connection get a fine probe and gently nudge all the legs on the bigger chips and pay attention for corrosion,to find a broken trace look for any dark spots on the little sines that go all over the main board
Here’s a video that should help
https://m.youtube.com/watch?v=ref9JHUf-u...
To try these methods you will have to take the calculator apart by following this video guide
https://m.youtube.com/watch?v=d8DzQoj4wp...
Unfortunately there aren’t many guides on taking the full thing apart so you might have you take some screws out and see where it takes you:-)
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sagar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 762
