メインコンテンツにスキップ
Apple AirPodsは2016年12月に発売されたワイヤレスヘッドホンです。
20回答 すべてを表示
How to charge airpods without case
How to connect aripods without case and how to charge them without cass
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
AirPods, those nifty wireless earbuds, are known for their convenience. But what if you misplaced their charging case? Unfortunately, unlike some phones that offer wireless charging capabilities, AirPods themselves lack that functionality. The charging case is integral – it not only stores your AirPods but also inductively charges them.
So, while the internet might be full of "hacks" for case-free charging, these are best avoided. They could potentially damage your AirPods or worse, cause a safety hazard.
If you're stuck without a case, your best options are to replace the case or consider a new pair of AirPods altogether.
You can see more:
https://support.apple.com/en-vn/guide/ai...
https://barcodelive.org/how-to-turn-on-a...
https://support.apple.com/en-vn/HT207012
さんによる
コメントを追加
2件の回答
ベストアンサー
So I am going to be 100% Honest and please bear with me
Now there is no way that this they can be charged without the case. Do not listen to any guides saying to put stuff in your airpods because you will damage them. The only solution is to get a replacement case, you can choose to get one from apple, or ebay. Only difference is cosmetic
You can connect them to a device without the case, if you connected to them before. The case charges the airpods and put them in setup mode for pairing.
PS - This below is a livesaver to help find the case when it goes missing
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Just like driving a car with not fuel it is just not possible! You need to get a new case.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Loki Yt さん、ありがとうございました!
統計データ:
過去 24時間: 41
過去 7 日: 240
過去 30 日: 931
今までの合計 30,677
