Battery fully charged but camera dead
Dead gopro 4 silver even with fully charged battery
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
If your GoPro isn’t turning on I would try a good SDcard (that’s compatible)and if you have tried that ,open it up and have a look for anything strange in the main board
Keep a eye out for corrosion as it’s quite common on GoPros as people sometimes forget to put the waterproof housings on them
Here’s a guide on dismantling it
If you see any corrosion try cleaning it away with some isopropyl alcohol
If it’s all clean on the main board I would start looking at the flex cables and if they are all good try plugging it into the GoPro Quik app as it might just need a update
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 400
