How do I replace a wheel?
How doI replace damaged wheel on my walker?
I don't know what the specific walker.
But often things with hard plastic wheels use standard ball barrings that's also used on skateboards, rollerskates and scooters.
A good place to buy new bearings is a skate shop, since they will usually be in the correct size, and of good quality.
The hardest part is getting the old bearings out.
Heres a guide for doing it on roller skates but if you look at method 3, that should be applicable to all things using similar bearings
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 858
We need to know the make and model number if you have one as they are different.
mayer さんによる 共有
