メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
623回答 すべてを表示
Top Left side Overheating MBA Early 2016
MBA 2016 gets heated on the top left side. And loud fan noise is audible. After that, the system slows, hangs and restarts automatically. This happens after every week or so of doing 3 hours web browsing daily. This is happening for the last 3-4 months. I always put it to sleep. There are 50-100 tabs opened at all times on both Chrome and Safari.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
さんによる
Unable to take screenshot. So just posting the results here:
Cycle Count: 631
Battery Status: Good
Battery Temp: 35.3 C (currently charging at 32%)
Charging with : 23 Watts
Power Adapter: Connected
さんによる
@Kunal Jain - What is the batteries manufacture date?
さんによる
It's May 2016
さんによる
コメントを追加
1 件の回答
While we often point people to count the cycles as most folks run their battery hard, its not the only measure, Age is also a factor! Given its age I'm sure this is the original battery! Batteries only last for three to four years as the chemistry breaks down.
The left side is where the charger connects the MagSafe connector can often heat up (warm) as the power feeding though it has enough resistance, but a weak battery also demands more power pushes things getting it very warm!
So to fix things you need to make sure the MagSafe connector interface is clean as a dirty connector can make things worse. You may need to replace it if it's become warped. MacBook Air 13" (Mid 2013-2017) I/O Board and he's the guide MacBook Air 13インチ Early 2015 I/Oボードの交換
But even that is not enough! You need to also replace the battery too! MacBook Air 13" (Late 2010-2017) Battery
MacBook Air 13" (Mid 2013-2017) I/O Boardの画像
製品
$79.99
MacBook Air 13" (Late 2010-2017) Batteryの画像
製品
$69.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kunal Jain さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 33
