メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
De'Longhi BCO430は、ポンプ式エスプレッソマシンと10杯分用ドリップコーヒーメーカーが一体になった、フロス用ワンド付きのシルバーとブラックのコーヒーセンターです。
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
画像
画像
画像
Did these images come ok?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
さんによる
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
iFixitでの質問に画像を追加する方法
さんによる
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
さんによる
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
さんによる
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
さんによる
3件以上のコメントを表示
コメントを追加
These coffee makers often are similar. Compare to Saeco Magic Capuccino SIN017のボイラー取り外し and Starbucks barista , perhaps it helps. Good luck!
Starbucks Baristaの画像
ガイド
Starbucks Baristaの分解
難易度:
中レベル
Saeco Magic Capuccino SIN017 ボイラー取り外しの画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Pics attached - this is how far I could get
Update (10/08/2022)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Update (10/08/2022)
画像
画像
画像
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
liluet_hernandez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 448
