メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech Wireless Desktop MK710(2013年発売)の修理ガイド、分解情報、トラブルシューティング。
Water damage of LogitechK710 keyboard
I have a logitech K710 keyboard that I spilled a water on the keyboard 2 weeks ago. I immediately turned it over and drained the water, I set it to dry for a day (flipped over), and then I took all the keys off and dried any moisture left. But still there are certain keys that aren't working, most importantly the space bar doesn't work. What's the next step? I'm hesitant to take it into get repaired as it was only a $60-$70 keyboard/mouse set.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi
The best thing to do here is to open it up and give everything a good clean with isopropyl alcohol and some cotton buds/q tips
When water comes into contact with electronics it can cause it to corrode which can cut the flow of electricity
Once fully dismantled and cleaned inspect for any burn marks and broken traces as if you find any you can restore them by running a jumper wire or using diver conductive paint
Once open if you could upload some photos using this amazing guide it would be amazing
iFixitでの質問に画像を追加する方法
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
wrestlerxtr1 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 14
今までの合計 347
