メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy A72は、2021年3月に発売されたミドルレンジのUSB-Cスマートフォンです。90Hz駆動のSuper AMOLEDスクリーン、Snapdragon 720Gチップセット、6~8 GBのRAMを搭載しています。
Samsung A72 Black Screen
So I make it clear and short.
My screen broke after I dropped my phone, I changed the screen and everything was fine at first. When I put the cover the screen started going black (touch and everything works fine though).
I got rid of the case after the service shop said there is no problem with the new screen. I noticed that when a certain area was pressed the screen went off (added a photo for illustration)...to turn it on I had to press power button couple of times. Until it just stopped turning on.
I sent to that same service shop they changed the screen but it would turn on again.
Phone still vibrates and everything its just the screen. Any idea what it could be??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@drein just to clarify, it has the same symptoms even with another screen? Try to add your piscture to your QUESTION by using this guide iFixitでの質問に画像を追加する方法
さんによる
Yes, same symptoms. Screen is black but phone works!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
With it happening with two different screens it is possible that the FPC connector on the board has been damaged since it doesn't work at all now. Sometimes the new screen FPC connector can be slightly too big and cause damage, or they can come loose off the board if disconnected improperly. You could always try another screen, but I believe it would most likely be related to the connector on the board or smoother board issue.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks a lot for your answer. As far as I understand seems like it only needs some soldering in the connector part.
さんによる
コメントを追加
回答を追加する
drein さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 23
今までの合計 1,380
