My pc cant detect it
its not showing on the iconx manager and device manager
@borj.leevan
Just verifying that you checked under "Other Devices" in Device Manager?
I think that maybe the USB drivers are in the Gear Iconx program folder.
Go to C:\Program Files (x86)\Samsung\Gear IconX) hopefully you will find the file SAMSUNG_USB_Driver_for_Mobile_Phones.exe
Try installing the drivers by clicking on the .exe file
このアンサーは役に立ちましたか?
I already installed it but nothing happened? I tried an app called driver fixer and while its scanning i saw a smr150 usb device there but after its done scanning i cant find it anywhere again
@borj.leevan
Have the earbuds worked OK before when connected to a PC?
Please don’t use those garbage programs. They just slow stuff down, risk installing the wrong thing, and trying to take your money. @borj.leevan
過去 24時間: 1
過去 7 日: 3
過去 30 日: 28
今までの合計 875
9 件のコメント
Hi,
Have you tried another USB cable?
jayeff さんによる
Is it even paired to the computer? Every once in a while Windows won't work with certain devices because it need a "driver." But, you can still go into Settings and check "Bluetooth and Devices" to see if it is showing up there. You could also try deleting the headphones from your devices list and then pair them again.
lyonmissions さんによる
Yeah i did, its just making the sound but can’t find it anywhere @jayeff
borj.leevan さんによる
I mean the device is not readable @lyonmissions
borj.leevan さんによる
@borj.leevan
Just curious if it shows up as a storage drive in Windows Explorer?
Also have you checked in Hidden devices in device manager? (Device manager > View > Show hidden devices)
jayeff さんによる
4件以上のコメントを表示
