screen is full black
screen is black but i can recieve the call by guess.
The LCD layer of the screen is most likely cracked which will result in no image being displayed on the screen. You will most likely need a new screen to resolve the issue. You can also always check the connection from the screen to the board as in some rare cases the flex cable can become slightly disconnected. Liquid damage can also cause this symptom. Just mentioning in case the device was near liquid recently.
このアンサーは役に立ちましたか?
If your screen is completely black but you can still receive calls, there are a few troubleshooting steps you can try:
If none of these solutions resolve the issue, it's possible that there's a hardware problem with your device's screen
このアンサーは役に立ちましたか?
so if your phone showing black but you feel THAT ITS ALIVE LIKE VIBRATING OR screen is a lil glowing that means you have a soft brick. ok now press power+vol up button then enter recovery mode then you recover from there.
このアンサーは役に立ちましたか?
Well black screen but still receives calls, it means the phone is powered on, but the display isn't working properly. Well you can do is check your phone for any physical damage on your phone screen and try to Force Restart the Phone if the screen is still remain full black it means Software crash or boot loop without full failure.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 815
Screen change phone m30 samsung
Sunil Agarwal さんによる 共有
Screen is black nothing I can see
gadgets world さんによる 共有
My phone screen is getting black day by day. In starting it is very small gradually increasing
SURYMANI KUMAR さんによる 共有
