メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy A22 5Gは、Samsung ElectronicsがGalaxy Aシリーズの一環として開発・製造したミドルレンジのAndroidスマートフォンです。2021年6月24日に発売されました。このスマートフォンには、トリプルリアカメラ構成と90 Hzの電子ディスプレイが搭載されています。バッテリー容量は5000 mAhで、iPhone 13 Proのバッテリーより62%大きくなっています。
Fingerprint scanner not working
The button is working properly but the sensor is not working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
5 件のコメント
It's f42 5g but it's not working but after restarting it's starts working for few minutes only.
さんによる
Sensor not work button is ok
さんによる
Fingerprint not working sencer
さんによる
Please working my fingerprint option Please 🙏 😢 Please
さんによる
Finger print not working
さんによる
コメントを追加
5件の回答
最も参考になった回答
@siddhantsen @gulfamkhan @fathimaraihana the very first thing you want to do, is to tell us what you all have tried to fix this. You have to determine if this is software or hardware related. A couple of common things to do, is to do a soft reset first. Then check for any software updates. Make sure you have the latest software for your phone. So go to your phone's settings menu, then look for the "software update" or "system update" option. If there is an update, download and install it. Next clear the cache and data of the fingerprint scanner app. You should also remove and then add your fingerprints once more. For more of all of this, check Samsung's advice on here
If none of this worked, you should consider replacing the fingerprint scanner. In the case of your phone the fingerprint scanner and the power button are combined. Since there are no guides on iFixit for this (yet) use something like this video to replace it. Remember that you need to purchase a proper replacement for your version of the A22 (SM-A226B, SM-A226B/DS, SM-A226B/DSN) to ensure compatibility. You can purchase those at many places online. Pick a vendor that meets your expectations.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
画像の内容を見る:
画像
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My phone fingerprint not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes is now working as manual
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
مشلكة لايوجد البصمة a22
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SIDDHANT SEN さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 38
今までの合計 2,981
