メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年10月にAppleによって発売された第3世代の高性能タブレットです。モデル番号はA1876、A2014、およびA1895です.
Need Help Identifying Component Q2201
Hello. I am troubleshooting an iPad Pro 12.9" 3rd Generation for no touch. There is a component that has a visible burn mark on it that needs to be replaced, but I cant seem to find what it is. ZXW Tools doesn't have any information about the component itself, only the lines connected to it and where they go.
The component is called Q2201 in ZXW Tools. Can anyone identify this component? I can't read the markings on the component itself due to the burn mark. Previous/newer generation iPad Pro 12.9's all seem to use a different component in the circuit here, so I haven't had any luck using another model's schematics/boardview to identify the component in question.
Board number for my model is 820-01435-A.
Thank you.
画像
Update: Luck would have it that another customer brought in the same iPad model for a screen replacement, so I took the shield off and took a look at their component.
It is marked, "FP G3" or "G3 FP", I guess. Attached is pic. Hopefully this helps someone?
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi
Since neither of us have schematics we can figure it out another way
If you can provide some photos of the burned chip and other things surrounding it I can find a image of a new board and give you some more information on what it is
Also here’s a amazing guide on how to add photos
iFixitでの質問に画像を追加する方法
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hello. Thank you for the reply. I edited the original post to include a photo from another customer's iPad that came in which is the same model as the one I was initially trying to repair. Their component is not burned, so I was able to get a clear photo of it. Description and photo in original post. Thanks.
さんによる
@techwizards
Thanks il let you know what it is when I find out :-)
さんによる
@techwizards
I cant find out from its name
Il try find a schematic:-)
さんによる
コメントを追加
回答を追加する
TechWizard さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 650
