SD card not inserted
Why my SD card is not inserted but I oredy try some ways from YouTube buy its still not working ! So can you tell me to insert the SD card ....
Hi,
The SD card is inserted with the gold contacts facing down, next to the SIM card on the tray. It should only fit in one way due to the notch in the card that lines up with the tray outline.
Here's a link that shows how to remove the SIM tray and you can see the SIM card is already placed in the tray and the empty space is for the SD card.
If it is inserted correctly and it is still not detected, try mounting the card and check if it is now being detected. Go to Settings, tap Device care > Storage > Advanced. Under Portable storage, tap your SD card, and then tap Mount.
If still no good try formatting the SD card. Go to Settings, tap Device care > Storage > Advanced. Under Portable storage, tap your SD card, tap Format, and then follow the prompts.
If still no good try another SD card.
このアンサーは役に立ちましたか?
Possible sd reader damaged if card inserted incorrectly. But as @jayeff says they only go in one way.
過去 24時間: 5
過去 7 日: 6
過去 30 日: 12
今までの合計 900
