メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GoogleのPixelスマートフォンの第3世代の一部である3aは、Googleのフラッグシップ機と同じカメラを搭載した、予算重視の選択肢です。カラーはClearly White、Just Black、Purple-ishの3色展開。2019年5月発売。
Device screen black after replacing battery
I've replaced the battery in my Pixel 3a, and even though it appears I reconnected everything, the screen continues to be blank. It vibrates when I use the fingerprint sensor and plug it in, so I'm not sure what's going on. I would take a photo, but this is my only camera.
I've also tried hard shutting down my phone and reconnecting the screen before turning it back on, with a similar lack of results.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
If you had to disconnect the screen ribbon I’d check the connector on the board and ribbon under magnification for damage. Also how did you remove the old battery? If you used something to lever the battery up there’s a chance pressure could of been put on the back of the display itself.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
I removed the battery by pulling off one of the adhesive strips as instructed in the iFixit guide, then the other strip's tab pulled off without the adhesive, so I had to heat up the back of the phone and pry it off. The entire time, the screen was disconnected and set aside.
Also, checking both under magnification don't reveal anything that appears damaged.
さんによる
Unfortunately sounds like the screen has been damaged during removal. I had to do a battery on the same phone last week and used heat and isopropyl alcohol to remove it, took a while as only inserted the removal tool a mm or two to prevent catching the side of the screen inside. Did you try the screen after removal to make sure it worked ok?
さんによる
@strongbow I don't think I did, or at least before I replaced the battery. I guess I'll have to get a replacement screen, then.
さんによる
Also did you disconnect the battery before anything else? Sorry just trying to rule things out.
さんによる
@strongbow Yes, I disconnected the battery last.
さんによる
1以上のコメントを表示
コメントを追加
I was leery of even trying to venture into replacing the battery on my Pixel 3a, but then after watching the instructions and an youtube video, I ordered the kit. Carefully and cautiously following the instructions, everything went smoothly and slowly. When all was done and the battery was presumably re-charged, I immediately tried turning on the phone. And there was just a black screen and - nothing. That was a big disappointment, but I decided to re-try everything again, step by step, leaving the phone "to rest for a day". And then, when I tried to turn on my "dead phone" after two days of just "resting", it miraculously "revived". It's been working perfectly well since then (end of May 2024). Where was the catch? In my eagerness to triumph after "I did it", I oversaw the sentence about the "(re) calibration of the battery" at the end of the whole process. It takes (some) time and it happened during the "rest" period.
Arthur Shi's Guide is perfect, it should be read and followed carefully. In the case of my Pixel 3a I didn't have to apply heat (iOpener) to "open" the phone, just slowly and carefully used picks (labeled 1mm and 6mm with a Sharpie on picks). Thank you ifixit, thank you Arthur Shi.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Wayward Horizons さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 32
今までの合計 1,213
