Why do I have lines on my paper when printing?
How come when I print I am getting black lines on the copies?
Update (07/26/2022)
We have a HP Color Laser Jet Pro MFP M479fdw
First try a fresh Ink cartridge to see if the drum is damaged. If the lines are present on the paper in the same way then the corona wire needs cleaning or replacing How to change a corona wire
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 459
Please add an image that shows what the lines look like, it would make it easier to understand the problem. iFixitでの質問に画像を追加する方法
Erik Eriksson さんによる
how do i attach a copy, to show what it is doing?
Lenette さんによる
@glcs74 Take a picture with your phone, if you are writing from a computer you can mail the image to yourself to access it from the computer.
Then follow the instructions I sent in the comment above. :D
Erik Eriksson さんによる
