How to replace charging port
The charging port is loose and the power brick does not charge the laptop, how can I replace the port on the MoBo?
Hi,
Here's the hardware maintenance manual for the laptop.
Go to p.92 to view the necessary pre-requisite steps and then the procedure to remove/replace the DC-In connector. If it is faulty it cannot be repaired, it needs to be replaced.
Search online for 04W6989 to find suppliers that suit you best.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 5
過去 30 日: 31
今までの合計 795
