メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Googleの第3世代Pixelブランドスマートフォンであり、同社初の「ノッチ」付き端末です。6.3インチのQHD+ OLEDディスプレイと64GBまたは128GBのストレージを搭載しています。カラーはNearly White、Just Black、Not Pinkの3色展開です。
Part for insulation tape?
Changing my battery due to the phone overheating and I noticed the insulation tape was torn. I cannot seem to find a replacement part for this anywhere. Can anybody point me in the direction of the part or a workaround to fix it?
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi
I wouldn't worry too much about this tape as it docent appear to be connecting to anything,heres what I would do!
try your best to straighten it out and get some non-conductive tape such as sellotape or electricians tape to put on top any that should fix your issue the best I can be fixed as I don't know of anywhere that would sell you a custom cut piece of this type of tape.
if you have anymore questions please ask
hopefully this helps
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
This is what I was thinking of doing but had one thing holding me back. That insulation tape seems to be connecting to a heat sink from the battery to keep the board cool. Will electrical tape be able to transfer the heat from the battery to that heat sink?
さんによる 共有
@Justin O
I don’t think it would matter too much as tape is horrible for transferring heat(that sort of thing wouldn’t make a difference in a cooling system)when its that thin,I think the tape is more just part of the manufacturing process rather than a essential part of the phone so the electrical tap will do just fine:-)
さんによる 共有
Thanks, going with the electrical tape for this!
さんによる 共有
@Justin O
That great:-)
さんによる 共有
I tried using some metal foil tape, thinking it would conduct heat better, but now my GPS isn't working. I think the foil is shielding, reflecting, or otherwise interfering with GPS satellite signals. So don't use metal tape!
さんによる 共有
2件以上のコメントを表示
コメントを追加
To anyone else watching this thread, this isn't regular tape. This is a graphite thermal pad.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Justin O さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 33
今までの合計 848
