メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
W124は、1984年から1995/96年まで製造されたMercedes-Benz E-Classの社内シャシーコードであり、公式にE-Classとして呼ばれるようになった最初の世代です。W124モデルは1984年以降にW123モデルの後継として登場し、1995年以降はW210 E-Classへと引き継がれました。 北米では、W124は1985年から1996年モデルまで販売されました。
intermitin hard start and running problem
my '92 300E i6 has started to act up . Hard start and acts like the timing is retarded, then starts and runs fine. Sometimes the throttle needs a soft touch or it stalls. My guess is a sensor but I don't know where to hunt for one..
Update (07/20/2022)
replaced both water temp sending units on the head. Car starts and runs fine till it gets to operating temp, then it stalls and backfires. It is not running hot, water level is fine, lower and upper hoes are hot so it isn't a sticky thermostat. I'm stumped.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
This question was migrated from https://meta.ifixit.com/Answers.
さんによる
E320 don't start the work turne but the engine don't and there is no electricity on spark plugs.
さんによる
コメントを追加
3件の回答
ベストアンサー
I replaced the fuel filter and it cured the problem. $14.oo at Auto Zone and it took 1/2 hour to replace it.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Without knowing what you tried, that can often be attributed to dirty fuel injectors or bad spark plugs. Check the spark plugs and see if they are dirty, and if they are just replace them and rule out the possibility. As well as that, you may want to run something like Techron through the fuel system and see if that helps clear out the injectors. You can do both at once, or one at a time. Same with the air filter; check for dirt, and replace the filter if it's dirty.
Those Benzes also tend to have a wire throttle body (sometimes called a DBW throttle), so check the wire and throttle body aren't damaged. You can also hold the wire down by hand and you do this with the engine idling, not hold it and then start. If you hold it down, don't do it too long - 15 seconds max. You want to see it sustain a load, not test the entire RPM range.
The other option is to try an Italian tune-up as well, if you can legally do 60-80mph and keep the engine RPM high (and can be safe while doing so). Sometimes if just Techron fails, you need to combine it with an Italian tune-up. Where I'm from, fast driving is mostly normal, so someone doing an Italian tune-up isn't be unusual but YMWV on how "normalized" speeding is. It's also kind of gas intensive, so erm keep that in mind a bit. These older i6 engines don't drink as much gas as a S600 with the M120, but it's a definitely a factor during the gas crisis.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
It is still on the trailer and I'll take a look at it Sat. I need to finish the propane truck I didn't get to today. Thanks for your tip, not sure what you mean by a "wire " throttle body but maybe when I get into it it'll be obvious. I've been driving this car for 3 years and this is the 1st problem it has given me. I'll update you when I figure it out.
さんによる
It usually runs on the front or back of the engine, sometimes the middle. It's pretty obvious once you know what to look for. Generally, on the i6, it's on the front if it has one.
さんによる
still not operating, starts and runs till it warms up then quits,
さんによる
try to fix the car computer its happened with me before.its a car computer problem.
さんによる
コメントを追加
Sur ma Mercedes w124 e250 elle démarre très bien le ralenti elle le tien bien mais une fois que je vais rouler au bout d'un moment là voiture va brouter perdre en puissance jusqu'à fumé blanc et s'éteindre et il faut attendre ~10 min avant de pouvoir la redémarrer pour qu'elle recommence plus loin
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
gsteele さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 38
All Time: 3,918
