does not heat water
washes with cold water only.it does not heat water
Open it. Look for the heater and measure its resistance. For a 230V Type ist should be near 24 Ohm, for a 120V Type around 10 Ohm. And: there is a pressure switch that ensures that the heater only works when there is enough pressure.
このアンサーは役に立ちましたか?
Hi - I was able to repair the Bosch dishwasher with this exact problem. It is an issue of the relay as described in this video:
https://www.youtube.com/watch?v=Jb8gAnMb...
You need to get an NTE R46-5D12-6 relay and replace it. Less than $5 part.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 561
Hi,
Please confirm the model number of the dishwasher.
It seems as though the heater may be the problem and if your dishwasher model is not a Bosch SRI45T45EU-18 anyone answering your question may link the incorrect part suitable for your model.
Moderator
jayeff さんによる 共有
