メインコンテンツにスキップ
Device not charging after 1%
I plug in my device using several chargers to test if it's the charger is the problem but it won't work. After I plug it in the battery sign show that it's charging and after it turns on at one percent its not charging when it's on and I can't stop it from turning on automatically
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント:
Please answer
さんによる
sounds like u have to take the battery out and put it back it sometimes tablets do this do to their poor design
さんによる
or could be the cord is malfunction that happens to do to another poor design
さんによる
The battery cannot be removed
さんによる
how does it work if there's no way to remove the battery that means there's no way to put it in either? your logic man
さんによる
コメントを追加
1 件の回答
If it charges in the beginning and you do not move it then there is no reason to think that it is a bad cable or connector.
The most likely issue is a spent battery. See if you can find a battery test app and run that to see what the health of the battery is.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Ok thak you very much
さんによる
how about a rating if it helped?
さんによる
コメントを追加
回答を追加する
Millie lee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 18
今までの合計 1,104
