@jayeff The headset does not die after the beeps and flashing, it just turns off. When I turn the headset off and on again it will go through the same issue of 2 minutes fine and then the 3 beeps and green flashes. I have not timed the charging, but it seems to be normal.
@jayeff I understand what you mean now. The tone that is being given is not the same as the usual dying tone. The headset is pretty old now, I'd say around a year. When I turn it on it says that it is currently at 97% and that was off a fresh charge from about 9:30.
1 year is not really that old for a battery but .....
Does it do this if you use the headset with the charging cable plugged in?
Just trying to eliminate or confirm the battery as the problem as to me it sounds power related somehow. Can't find any info regarding warning tones (other than battery related or muting) and nothing about the green LED flashing
Hi @thiccc_ice
How long does it take to fully charge the battery again if you charge it immediately after it beeps 3 times etc and then turns off?
jayeff さんによる
Gary Jackson さんによる
@thiccc_ice
I was just wondering if the battery is failing as the manual states that a tone is heard when low battery levels are reached.
It may be that the battery is failing to hold its charge.
How old is the headset? Even rechargeable batteries have a lifespan.
jayeff さんによる
Gary Jackson さんによる
@thiccc_ice
If it doesn't then maybe replace the battery.
jayeff さんによる
3件以上のコメントを表示
