メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
iPhone 4S takes too much power but wont charge.
Hello, my iPhone 4S was working/charging properly until today I wanted to charge it once it was at 50% plugging it in didn't do anything but made the cable very hot, the iPhone was still working but didn't make the charging noise.
Once I plugged it into my laptop using another cable t said that one of the USB devices (iPhone) was taking too much power.
So my iPhone takes in too much power, overheats the cable but won't charge with any cable/adapter.
I will not be using my iPhones last 50% until I hopefully fix it up.
Any help is appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
heating means there is short. Best would be check cable on other phone. also check there might be some metal in plug of iphone, but that in unlikely. I would say there is short near socket on board. You should feel what is getting very hot when it is open
さんによる
@komota I have tried your method, the cable is the one getting hot not the iPhone. The cable only gets hot for this particular iPhone. The other cables do not get hot but neither won't charge. But thanks for your reply.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Bwar Bahzad first start off by replacing the battery. Get a quality battery and then recheck. If you have an USB Ammeter, check the amperage your phone draws. IF a new battery does not resolve it, replace the dock connector.
iPhone 4S Battery Replacement - iFixit Repair Guide
iPhone 4S Dock Connector Replacement - iFixit Repair Guide
iPhone 4S バッテリーの画像
ガイド
iPhone 4Sのバッテリーの交換
難易度:
中レベル
10 - 30 minutes
iPhone 4S ドックコネクタの画像
ガイド
iPhone 4S ドックコネクタの交換
難易度:
中レベル
25 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bwar Bahzad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 68
