メインコンテンツにスキップ
Oral-B Triumph v2は電動歯ブラシシリーズです。 Oral-B ブラック7000を含むモデルです。
6回答 すべてを表示
Runs down and stops in about a second
My toothbrush runs down and stops in about a second. I fixed the problem a few months ago by unsoldering and then resoldering the battery. I have checked the battery voltage during the switch on, slow down and stop phase and it remains constant at about 3.7V so there would seem not to be a problem with the battery. When the problem occurred before I found that bypassing the MOSFET caused the motor to run normally at full speed, so this seems to be a microprocessor issue. I have tried resetting the brush by holding the power button for ten seconds. There is no water inside.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Fixed - there is a polyfuse marked PP which is Bourns MF-PSML300 rated 3A and it was dropping several volts. Bypassed fuse with multimeter on current setting, toothbrush works and meter reads 0.5A so fuse clearly faulty. Bridged fuse with solder for permanent fix. It is possible to buy replacement fuses but they are expensive and not easy to fit.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
bypassing a fuse is never a good idea for a long term solution. SMD parts are not simple, but this part is big so it should not be a big problem.
These are 0.18¢ each - min quantity 10.
https://www.aliexpress.com/item/22518327...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I had the same problem with a similar OralB toothbrush. It would charge and start, but run down in 1-2 seconds. Battery seemed fine, but the polyfuse measured 3-4 Ohms. That's completely out of spec. So I replaced it with a tiny strand of wire. Works again as before.
Thanks for the pointer!
さんによる
That's a 1206 package, OEM is an 0805
さんによる
コメントを追加
回答を追加する
Tim さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 50
過去 30 日: 179
今までの合計 12,582
