メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
pc not having power when cpu is installed
Hi, i recently upgraded my pc however when i installed the new cpu the pc will not have any power supply as well as when i intall the previous cpu. have i damaged the motherboard? or is there something else ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@joshwaltisbuhl upgraded how.? Since we do not have any info we will need to know your mobo make and model, your RAM make and model and you PSU make and model. This could beca compatibility issue.
さんによる
Hi
Could you provide us with a photo of the cpu socket from a birds eye view as square as you can get it with good lighting please
Just so we can check there’s no bad pins that are burned or misaligned
But as @oldturkey03 said :it could be a compatibly issue:-)
さんによる
コメントを追加
1 件の回答
最も参考になった回答
A detailed list of events of your install might lead to an answer. If you happened to insert the CPU incorrectly, that might create serious issues. If the MB is not secured properly to the chassis, you may have a short == but that should show up without the CPU. If the heat sink is not properly installed, that could fry the CPU in a heartbeat.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
joshua waltisbuhl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 77
