2015 rMBP Still having same problem after logic board swap
Previously I asked for help with an issue on my laptop on this forum. Shortly after buying this laptop used it slowed down, as well the fans spin up to full speed shortly after startup.
I ran diagnostics and it returned a result of "SMC issue. with code PFM006". I then took it to an Apple store and they ran their diagnostics. They didn't get the SMC error. But they did say there was something wrong with the SSD connector.
The suggested solution was to replace the logic board. And so I just did that. However I am getting the exact same behaviour. The laptop runs incredibly slowly, and the fans spin up to full speed shortly after startup. And when I run Diagonstics I get the same error of "SMC issue. with code PFM006".
I'm kind of stumped. Both the Apple genius, and suggestions from my other thread led me to replace the logic board. Is there anything else besides the logic board that would cause an SMC issue?
My previous thread is found at Temperature sensor locations for 15" 2015 MacBook Pro
Thanks All
Image of new cable from ifixit
1件のコメント
@velvetlounger - Are you using the same SSD drive? Do you have access to a second one to see if the SSD its self is the issue.
Dan さんによる
