Backlight spots at bottom of screen
I swapped the display and logic board (the old screen had the same problem but the display was broken, and the keyboard in my other MBP was broken) and this wasnt there on the old chassis
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 148
5 件のコメント
@danby that is stage lighting and is caused by a failure of the backlights. Check the display connector voltages and check the filter capacitors around that connector. It is possible that you a. have a bacd connector b. Bad capacitor or a bad backlight/display. Let us know what you find out after you have checked
oldturkey03 さんによる
Either I'm confused or you are. You say "the old screen had the same problem" and then you contradict yourself by saying "this wasnt there on the old chassis".
You're looking at either a bad video connector, a bad video cable, a bad display (I've seen many cheap ones from China looking like that), or (possible but low on the likelihood scale) a bad logic board.
Steve さんによる
My old 2012 Macbook pro had the same issue!
Ben Capehart さんによる
@beanman56 did you fix it with a new display or did you find the bad caps on the board?
oldturkey03 さんによる
@oldturkey03 - neither it broke (keyboard and motherboard)before I found out the issue
Ben Capehart さんによる
