メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
Components missing in an area of ​​the board
Hello. I need help!
I made a post about a component that would be missing from my board after it undergoes oxidation.
A collaborator helped me by indicating the missing component, but when looking at the photo sent by him I realized that more components may be missing.
Again I ask for the help of the community!
Thanks in advance for your help and I'm at your disposal.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
The best way to figure things out is by snagging the boardview drawings and schematics. They can be found on the Internet! Do a Google search for the board number 802-2530 sometimes it takes a bit of searching Like this
To help to locate if the files are out in the wild I reference this board Logic.WiKi
Between the two you should be able to ID any component on the board!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
The board is scorched by an overcurrent fire. The reason doesn't matter anymore - maybe a loose part having shorted the circuit. It should have been smellable.
You must replace the board. Look for a replacement board (eBay, iFixit etc.) and the procedure description in iFixit or elsewhere. I do this scores of times with a different MacBook, thus prolonging its life for eternities.
Good Luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
wagner.m.v さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 172
