メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Tab S7+ 5G (SM-T976B) は、2020年9月18日に発売された、Tab S7の大型でよりパワフルなモデルです。12.4インチのSuper AMOLEDディスプレイ、Qualcomm Snapdragon 865プロセッサを搭載し、5Gに対応しています。
Not charging after update
After updating the tablet to android 12, everytime I plug in a charger, a notification pops up saying "USB connector connected/disconnected" it keeps popping up every second and the device won't charge. I am using an original Samsung Charger
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
You can try a soft reboot (no data loss) press power and volume down buttonus simultaneously hold them until you see the tablet restart. Ignore the screen until you see the startup screen, release the buttons also check in settings and see if it is still showing available update.
さんによる
Mine just started having this same issue but this was both before and after the android 12 update. Updating didn't break it or fix it, for me at least, it appears.
For me, if I flip my new Anker cable around "upside down" it will work. If I put it Anker logo up, it disconnects/reconnects 3 times a second if connected to my Anker power bank.
My Anker super fast charger and it's different cable are the same way, but opposite cable direction.
Moral of the story, all of our cables decided to break at the same time, obviously.
No, it appears Samsung actually just broke all of our tablets at once. Thank you, Samsung. I don't think yours is physically damaged.
さんによる
コメントを追加
1 件の回答
I replaced now the USB charge unit and the battery. Both replacements don't solve the problem. For this case the temperatur sensor or the measurement device is placed on the mainboard. I hope this info helps other people on this webside.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Any fix ?
Mine is having same problem
さんによる
コメントを追加
回答を追加する
Roel Docto さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 34
今までの合計 1,482
