メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Screen backlight not working - Logic board working on other screen
It started with screen flickering then it went black. Shining a light through the apple logo, I found that the screen is working fine. The logic board was tested onto another screen and it worked fine, similarly another working logic board on my screen gave the same dead backlight. It cannot be the WLED driver nor the fuse issue since the logic board is working fine.
Now I can not find a clear fix for this, can anyone guide in the right direction.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Your process makes it clear the issue is within the display assembly and/or the display cable its self.
I would have just used a DVM to measure the backlight power on the logic board. But you process also works!
So you'll need to inspect the display cable contacts for damage it needs to look like this
If that looks OK, you will need to inspect the cable its self for damage and may need measure the continuity between to pins across the cable contacts once you've removed the cable fully from the display following this guide MacBook Pro 13" Retina Display Mid 2014のディスプレイアセンブリの交換 Once the display is off slide the black clutch cover to gain access to the display cable connection
The connector is just like the logic board, also look for corrosion damage across the soldered pins as well often I see the connector its self damaged. People over did the cleaning of the screen so cleaner often dripped down damaging the connector and shorting out the solder joints.
And lastly, here's the needed replacement cable: 13" MacBook Pro Hinge Left - eDP Cable, Apple P/N 661-02360
If the cable is OK then you have a deeper issue within the display assembly, I find its time to just replace the part MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assembly
MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assemblyの画像
製品
$449.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bas ma さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 229
