Blue Yeti Mic - USB fix?
Well I'm a complete noob to this BUT is this fixable? I got a new microUSB port thinking of just re-drilling the little holes for the pins and re-soldering ? any advice?
Hi @tb582
Use a soldering iron with some flux and wick to remove the excess solder so the holes would take a new usb port.
If you drill it, you will most likely damage the link between those delicate copper rings and the traces.
このアンサーは役に立ちましたか?
@tb582 listen to @honakrisi no drilling. You will tear the traces and lose the rest of it. Soldering iron, flux and desoldering wick to clean it up.
過去 24時間: 3
過去 7 日: 6
過去 30 日: 36
今までの合計 1,091
