メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech M170は、Logitech製のワイヤレスマウスです。2016年に発売されました。
Wheel randomly scrolls in other direction
Hi. The problem is when i want to scroll down or up it goes to the other direction, sometimes more or less.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 13
コメントを追加
2件の回答
最も参考になった回答
The trick is the WD-40 spray. It's a spray that can be bought at any hardware store worldwide. It's world famous. Just spray a little bit in the side of the mouse where the scroller uses a small wheel which is attached to the circuit.
I found many answers saying to use WD-40… at first I was very apprehensive, but it worked like magic.
Spray it, leave it upside down for 10 minutes and then test the scroll with an open top before closing it permanently. Amazing liquid.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
could you guide us on where exactly we should spray the WD40 im a little confused
さんによる
You don't spray directly onto the area. You spray into the cup (cover of the bottle), as shown in the video and use a stick to apply on the motor or the sensor.
Just see the video. You will understand
https://www.youtube.com/watch?v=cVKXUiXl...
さんによる
コメントを追加
From what I understand, we need to open up the mouse and clean the scroll. But the biggest issue is opening it up. Its super hard. There are 3 clips in the battery compartment. I have bleeding fingers trying to open it. No success. Maybe I need to buy an iFixit kit.
See these videos :
https://www.youtube.com/watch?v=Kem0TE3U...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It wasn't that hard to open the top cover. Just loosened the three clips using the below instructions:
Logitech M170の外装ケースの開け方
And then cleaned the scroll. It's working perfect now.
さんによる
コメントを追加
回答を追加する
Rafał Barański さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 24
過去 30 日: 99
今までの合計 2,809
