メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
battery discharge differential in iPhone 7
i have two iphone 7's. same model and memory capacity. i noticed one was draining it's battery faster than the other, so i ran some comparisons.
i made sure each phone was running one app and the background settings are the same. i know i should have probably timed them but didn't because i didn't have time to really monitor them. what i can say is that when the first phone hits the 20% warning, the other phone was always between 40% and 45%.
the only differences that i can point to are.....
1) the 20% phone is running IOS 15.2, the 40%+ phone is running IOS 14.8.1.
2) both batteries are original and are close to 85% health
3) the 20% phone battery has 774 charge cycles, the 40%+ phone has 380 charge cycles
so my questions are, can 15.2 or a higher charge cycle count be responsible for a faster battery discharge? or is there some place else where should be looking?
thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@beekerc there are many variable that can cause this. Yes, the charge cycles will make a difference as well as the iOS version. I would suggest that if you are not satisfied with the battery life on phone number 1, change the battery. Testing battery life against the other phone is just a pretty rough estimate. If you do want to test the batteries, run a test like I did on here. It tests the battery with the same load etc. Evaluating High Capacity Batteries (Part II)
iPhone 7 のバッテリーの交換
iPhone 7 バッテリーの画像
ガイド
iPhone 7 のバッテリーの交換
難易度:
中レベル
30 minutes - 2 hours
High Capacity Batteries (Part II)の画像
ガイド
難易度:
中レベル
10 - 30 minutes
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
agreed, there can be multiple factors. these three just seemed to be the most impactful, so i figured i'd start there. :)
based on the performance, it's probably due for a battery change, but if it were IOS, then a new battery shouldn't matter and change performance that much. if it is battery life or charge count, then a new battery could solve a lot. Generally speaking i don't swap out batteries until i hit the 70% mark or when it can't hold a charge worth crap.
unfortunately i don't have the gear you for testing, but i definitely understand the methodology. thanks for the input and insight.
さんによる
@beekerc the iOS can account for the differences in between the battery of different phones since it can/may regulate power consumption etc. You are right, in the same phone with the same iOS there will be no difference between old and new battery.
さんによる
コメントを追加
回答を追加する
B C さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 31
