How to disable retail mode?
How to factory reset while in retail mode without password???
The Retail Mode Password for S22 Series and Z Series are: Reta!l-9102
このアンサーは役に立ちましたか?
Bro I literally created an account just to say you are an absolutely awesome human being and I hope your life will be filled with as much joy as you provided me with the password I was about to root my phone going crazy looking for a solution. Thankyou for making my day I hope you'll always be filled with luck
Same. Thank you. It does work.
Hi all. Any idea for retail mode code for s21 ultra? 5444 and the code Reta!l-9102 don't work sadly.
Does anyone know the Retail mode Password for Samsung S20 FE please ?
Does anyone know the retail mode password for my watch 5
here are all the passwords for samsung i have. some are specific to where the device came from.
Walmart:
- rollback
- Walton
Bestbuy:
- blue
Target: (added 8/8/23)
- onthemark
Other Passwords:
- galaxy
- ruletheair
- rethink
- demomode exit
- instoredemo
- unlimited
- remove cod
- nationwider
- easy
- leap
- Reta!l-9102
- Ret@il-7398
Enter "Display Mode Settings"
Toggle "Enable Factory reset"
Follow prompts to uninstall demo app
このアンサーは役に立ちましたか?
Any one know a code for a Target Samsung tablet stuck in retail mode?
How about a code for a Sam's Club Samsung tablet stuck in retail mode. Tried all the ones above with no luck.
try the password "onthemark"
if all else fails you can use odin to reflash stock firmware on those devices. it's a little more difficult but you can find everything you need for free. there are tutorials on youtube about using odin.
@jason79421 i treid but because of retail mode it doesnt allow the phone to go into odin mode. only the stock recovery mode. help?
samsung note 10 (it DOES have an imei and is clear, NOT blacklisted)
I do not have retail mode on my device but I found these instructions:
Go to "Settings, then scrolling down and selecting General Management, and finally Retail Mode. This will bring up a screen asking if you want to turn it off. You can also do this by going to Settings, Backup and Reset, and finally Backup Storage - Backup Options. Then select Retail Mode Turnoff."
On several sites they say the password is 5444
It is also mentioned that if demo mode is all that works, it is a stolen phone and only samsung can fix it. If that's the case possibly you got tricked into buying a stolen phone?
このアンサーは役に立ちましたか?
I also am having the same problem my samsung S22+ is in retail mode and the password 5444 does not work nor does any of the advice I have found on the internet so far...I really would like a fix because everything resets every hour back to default
Ok, I didn't find this last time I searched, but there are very many different passwords on this page. One of them may serve, after reading this my advice would be to check with whoever you bought the device from, seems the password varies by the retailer or carrier. The solution that helped most but not all folks is the "chosen solution" on this page
How can get the list of passwords for A12 galaxy phonei have a version branded phone
I have create an account just for say thanks !!!
@uchetil Flashing a stock rom also helps.
I've got a Galaxy S22+ and 5444 doesn't work and not does the Reta!l-9102. I've tried all the passwords I can find. I did notice something that really made me wonder about my new device and that was when I am looked up the IMEI it was all zeros. However it was loaded with Android 12 and just got a brand new security patch on July 22, 2022. So this tells me that I was tricked into purchasing a phone that is completely useless. Any advice?????? I'm not trying to be easy for the person or persons that beate fory money but most of all the company itself. The Samsung People say that the device has not been reported stolen by anybody in addition the people who seemingly own the device and the accompanying rights and responsibilities are Samsung's responsibilities due to the fact the demo mode was downloaded from Samsung s website directly with an address that would be the Holiday Inn in South Bay Plaza and so I would have to guess that this phone was originally sold in the areas Best Buy store which is located at the same st. Just different numbers. Ok am guessing that I have to contact Samsung directly. Best of Luck and any help would be greatly appreciated
このアンサーは役に立ちましたか?
You got scammed from whoever you bought the phone from. Retail mode is only on demo phones. Even on the back of your phone it must say LIVE DEMO UNIT NOT FOR SALE. They do not have antenna bands inside them so no sim card will work.
Tell me how to takeoff retail mode on a Samsung galaxy S 23
that device does have radios but they are turned off. you can find a services online that can turn that into a real phone. theyre a bit pricey but it can be done.
Does anyone know where to buy these live demo or no imei phones I need loads to use them for parts
You bought a live demo unit model. You are not completely screwed. The phone is fully functional except the part where you can make phone calls and do texts. Also, there is a way to fix these demo devices to make them work as a proper functioning device however, there is no free method.
If anyone needed it for a xfinity mobile branded device, password xfinity worked for me !
このアンサーは役に立ちましたか?
If it's a specific network branded phone, try the name of the network. Example, xfinity mobile. The password xfinity worked for me!
I have Samsung Galaxy a32 so want to remove retail mode and I'm writing 5444 and Reta!l-9102 but it's not working anyone help me please
このアンサーは役に立ちましたか?
l needed this for my Samsung flip Z4 been looking out for like a year maybe lmao, the Reta!l- one was the one for me. Located in Bs As. Thank you everybody
このアンサーは役に立ちましたか?
Does anyone know the password to retail mode for sansung fold 5 its from best buy
このアンサーは役に立ちましたか?
not sure if you saw the answer above but best buy devices usually use the password "blue"
It's not working. I tried them all
Electronic1cs
Shhhh. I didn't tell you
I have no luck with my S22 from Best Buy United States… I’ve tried almost everything…
Does anybody have the password for retail mode exit on Samsung s23fe from spectrum
このアンサーは役に立ちましたか?
Does anyone know the password for galaxy S 24 ultra from T-Mobile
My phones and demo phone my galaxy S 24 ultra. I bought it from somewhere and can’t believe that happened and it’s from T-Mobile. Does someone have any type of security password or what should I do? They won’t even let me factory reset it
このアンサーは役に立ちましたか?
I need help, with Samsung fold 5 from t-mobile
このアンサーは役に立ちましたか?
Any luck unlockimg the Z fold 5? I'm about to buy one in retail mode for a steal price so I just want to confirm what and what I can access in retail mode and probably how to get out of it. Is all retail mode stolen phones
samsung note10 EE pleaseeeee
このアンサーは役に立ちましたか?
S24 secondary password on samsung retail mode platform
Anyone have one for a s21 Fe T-Mobile . Has imei as well and unlocked 🥹
Did you have the second password ?
hey i have a a53 from walmart it says north america but says the store it came from was greenwood and i have tried every password on here and nothing works it also is stuck in airplane mode so i can access no internet at all even when i put a sim in that works. nor can i factory reset any help would be appreciated please
このアンサーは役に立ちましたか?
I need help with z fold 6 remove Retail mode
このアンサーは役に立ちましたか?
Same problem do you find a second pass?thnx
Do you find the second password ?
Please anyone know retail password for Galaxy A13 5G. Been looking for it for long and no passwords above worked for me.
このアンサーは役に立ちましたか?
Anyone have the unlock password for curry's pc world in the UK. I have a s20 I got from a bulk lot of broken phones with mainly swollen batteries. Thanks
このアンサーは役に立ちましたか?
Well Checkout the following video: https://www.youtube.com/watch?v=Jypnhr7V...
このアンサーは役に立ちましたか?
Does anyone have the second password, i have a samsung s25 edge
このアンサーは役に立ちましたか?
hiii bro wat is the samsung fold 6 retailmode pass word
このアンサーは役に立ちましたか?
Hii tell me bro second password
For the moment many People want the famous password.
But nobody have the second pass 😪
For the Flip 6 / Fold 6, even with 2nd password entered and Retail Mode removed, I have found that Factory Reset is still disabled. Samsung have updated the embedded software for the S25 series, and the Flip and Fold 6 variants onwards.
You will find 2 apps active within Security settings -> Device Admin Apps. These are Configuration Service, and Enrollment Service. Both apps have the Deactivate option greyed out, which is required to factory reset the phone in order for it to behave like a fully functioning consumer unit, and have Google Play Store active
このアンサーは役に立ちましたか?
Can you give me the second password if i will can test if for me it's ok ?
For which phone, Flip 6 or Fold 6?
Password are différent if its flip or fold ?
Mine is ultra 25
But i take all password for testing 😅
I don't have an Ultra to play with, so not figured out the unlock for it.
I have worked out that the Flip 6 is: Fl!p62024!
Fold 6 is: F0ld62024!
Please find us all some results
Thanks. I will try with this maybe its ok
How do you find this password for flip et fold ? Maybe for ultra its same mecanic name number
Knox is strong 💪🏾🤣.
I test 50 probably password it's big fail 😅
このアンサーは役に立ちましたか?
How do you find this password for S25 OR GAMME 2025
Merci
Not for the moment unfortunatly i search everywhere but nothing or it's paiement
have you seconde password watch 7 samsung please
Does anyone have the second password for the s25?
Samsung s25 ultra retail mode password 2 send to me
このアンサーは役に立ちましたか?
Samsung s25ultra retail mode delete passwors.2 password tel me
過去 24時間: 11
過去 7 日: 74
過去 30 日: 358
今までの合計 86,507
8 件のコメント
Retail mode kaise hatae
Santosh Bharti さんによる 共有
Need retail code for Verizon z flip 5 please advise
Shane Campbell さんによる 共有
Samsung galaxy tab S5e retail mode password
Ismail Khan さんによる 共有
I have a note 9 on comcast / xfinity what the code for it
Maksims Dust さんによる 共有
Samsung A56 and Samsung A36 retail mode password
Sanu さんによる 共有
3件以上のコメントを表示
