メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
iMac 2011 Intermittenly will not power on. Usually works on the third
What is my problem? Power button itself? The machine works flawlessly and has been used by a friend for 1.5 years and now me for three months. Zero issues aside from strange power button issue. Thanks for any insight.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
The power button might need to be cleaned, as it might be sticking due to debris between the body of the Mac and the button. Otherwise, my assumption is that the issue could have something to do with the PSU. You can use this guide to get to it. See if you can find any damage to the board or the components on it (I.E, if any of the captors are bulging at the top).
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Follow this guide to Step 14, then jump down to Step 30 disconnecting the Power button connection iMac Intel 21.5インチ EMC 2428ロジックボードの交換 Use an Ohm meter to test the button plugging into the cables connector. If it is working correctly (which I suspect it is) then we need to look deeper.
Th power button signal is feed thru SMC on the main logic board which then in turn enables the signal to the power supply to turn it on. This allows SMC to over-ride the power on signal when there is a problem within your system.
I would locate your original Grey CD/DVD's, one will be marked as a diagnostic disk, reboot under it lets see if diagnostics passes. Given the age of the system you might want to replace the PRAM battery as it's about time to replace it. That maybe in fact be your problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Living Light さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 19
今までの合計 75
