Is this CPU compatible?
I know about delidding the CPUs for the 4,1 (which I have) but will the X5675 on this page work?
Here it says it will work,
But do I have to find a delidded version?
@oldturkey03
この質問は役に立ちましたか?
@oldturkey03
この質問は役に立ちましたか?
Hello @beanman56
Apologies in advance but I am not Oldturkey03
But I do know that the cpu will work in a Mac Pro 4,1 BUT ONLY IF YOU FLASH IT TO 5,1 I cannot stress this enough,in order for this to work you need to do it
As for de-liding people really like to charge a premium for delided cpus so I would order a deliding vise and to it manually
I have a 5,1 and it has the Intel Xeon X5675 so just a little more assurance for you :-)
Hopefully this answers your question
このアンサーは役に立ちましたか?
Uhh, I'm not that confident in being able to do it.
Thanks for trying.
No worries:-)
過去 24時間: 1
過去 7 日: 11
過去 30 日: 24
今までの合計 604
12 件のコメント
@beanman56 probably be easier that to match the heatsink like this http://forum.netkas.org/index.php/topic,... but will cost you way more
oldturkey03 さんによる 共有
Ughh.. could I just get a heat sink from a 2012?
Ben Capehart さんによる 共有
@beanman56 probably not. To easy :-) Just shim it. Couple of washers and you'll be set.
so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
@oldturkey03 - so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
7件以上のコメントを表示
