iStat Pro Report - Rear Main Fan 0 rpm
iBook bottom has always been extra hot. Recently replaced battery and DC in board. Runs great, but needs a thermal blanket. Should I replace the fan, or is more troubleshooting needed first.
Good job and thanks for coming back to share solution.
Found an excellent app - G4FanControl 0.6.1. Resets threshold settings. iStat now shows 8200rpm. Much cooler too. carlstaff, Feb 1 @ 10:42 PM
This answer needs to be accepted or voted up.
N.
このアンサーは役に立ちましたか?
Do you hear the fan when you watch videos on youtube or when you do intensives jobs ? If no then replace the fan. Cheap repair.
このアンサーは役に立ちましたか?
AKA- Flash
Most likely that istat is just not compatible with your iBook..
Their website advises that it doesn't work with most PPC Machines..
このアンサーは役に立ちましたか?
I highly doubt that it's a false positive.
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 1,633
2 件のコメント
carlstaff さんによる
Hi- good job solving it yourself, can you please though put this comment as an Answer instead and them Accept it so we can see what worked? Thanks.
rab777hp さんによる
