メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xiaomi製スマートフォン、Android One搭載、前面のペンタローブネジ
How to solve brightness problem after screen replacement?
Hello,
I bought an unoriginal screen to replace my broken screen on my Xiaomi MI A1.
I did the replacement but as it's not an original screen, there is a problem with brightness :
When I boot the phone, the Xiaomi logo appear with a normal brightness. But then, when the logo disappear and the home screen appear, the brightness become extremely low (can only be seen in a dark room).
Everything else works perfectly (touch, apps, ...).
Even if I move the brightness bar, the brightness doesn't change. I also tried to change it with apps but it didn't work either.
The weird thing to me is that the screen is able to have a good brightness (because when the phone boot the brightness is good) but when in use, the brightness is terrible.
So, is there a method to have a good brightness on an unoriginal screen after a replacement ?
Thank you !
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
@edwink this sounds like it is losing its backlight after initialising
さんによる
コメントを追加
3件の回答
最も参考になった回答
Hi Edwin, I went ahead and did a little bit of research and found that others (New LCD no brightness) that have done the same replacement have run into the same issue. A recommendation is to check the phone and to make sure everything on the inside looks proper, If that's correct then I would find a different seller for that screen or a new phone since the one can't be used normally without being in a dark room.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It is possible that when you replaced the screen that you didn't get the light sensor up against the screen or that it is blocked by debris of some sort. It is also possible that your auto brightness is on and set too low. Less likely it could be a software problem. While a reset might fix that you need a backup first. Try to contact the supplier for a possible fix or replacement. Good luck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
what if it's only the lock screen dat is dark
さんによる
コメントを追加
Battle Durga MI owner back scene
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Edwin さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 96
今までの合計 11,668
