メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第三世代の Surface Pro タブレットは、2014年6月20日にリリース。
Why does my surface pro 3 keyboard stops working
My surface pro 3 keyboard always stop working and most times I have to hard reset the system for it to work again but this time, it’s not working after all I did.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
This is the onscreen keyboard?
さんによる
No the physical keyboard
さんによる
コメントを追加
2件の回答
I do not have enough knowledge about surface pro because I am an ios user. But it seems like there is some software or operating system issue. That's why it stops detecting your keyboard and sometimes it got detected. You should reinstall once your OS before applying any hardware things.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The SP3 keyboard failure is a common one that happened about the time you asked this. All attempts at solving it have failed - restoring Windows, updating drivers, even replacing the keyboard with a new one. The only solution I've found is that there are several vendors on Amazon and such selling what look like the Microsoft keyboard but use Bluetooth to connect to the SP3. They also use USB-C to charge their internal battery. Otherwise are essentially form, fit, and function like the SP3's original keyboard. And far less expensive, too! They still attach like the original but can be used even across the room.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Victor Emeka さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 470
