Radiator Expansion Tank Fix
I have a 540i... the expansion tank spread apart, the two body pieces.
Do not get a new spare
I want to glue it... need to know what plastic it is made of and what adhesive I should use
Thank you very much
5 series and cooling issues. When these cars get old, things like hoses and apparently expansion tanks seem to go out.
I would strongly consider spending the big bucks and getting a replacement - even if it means begging at the dealer.
The problem with gluing is that you need both a good leak free seal and a strong one that can survive 200+ degree water. If you get the glue wrong, it will come apart again and you will have to clean off the glue to get a proper seal on your next attempt.
If it's a non-pressured tank, you can buy some really nice looking aftermarket/racing expansion tanks. If its pressurized.. forget it. Buy a new one.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 7
過去 30 日: 25
今までの合計 554
Polypropylene. I suggest finding bmw forums for more info. Be aware of glues for pp but may not be good enough for use because expansion tanks are under heat and pressure.
F Dryer さんによる 共有
