wifi and bluetooth not working
my wifi and bluetooth don't work after replace the battery
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I would reseat the I/O data cable which connects the I/O board (with the Airport board) to your main logic board often I find the cable connection is the issue, you may need to replace the cable MacBook Pro 13インチRetinaディスプレイ(2013年前期)出入力ボードデータケーブルの... if the Airport board is properly seated and the antenna cables are in good shape.
このアンサーは役に立ちましたか?
First thing I would check is to make sure that the antennas are plugged in properly. The order of the antenna cables is kind of weird (to me anyways). Step 10 of this guide tells you which one goes where.
MacBook Pro 13インチRetinaディスプレイ(2013年後期)のAirPortボードの交換
I would also make sure the cables between the I/O board and the logic board are seated properly, since that's what carries the signals for bluetooth and wifi over.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 19
今までの合計 642
